Main Menu |
Front Page / News Chat Links Message Boards: Trips & Reports: Classifieds: Registered Users: About / Contact Us:
February 8th, 2010, 07:15 PM
#1
Member #: 5979
Where to buy 14bolt rock ring? ok found one.
Im looking for a company that sells a 14 bolt rock ring so I can modify the stock diff cover. Searched DIY companies and only came up with RuffStuff. Anyone out there know of a less expensive option? I thought of making one but it isnt worth my time. Just looking for the base or mounting surface.
Like this:
__________________
Flick'n one bean at a time...
Please support White River Forest Alliance!
CLICK HERE
February 8th, 2010, 08:07 PM
#2
Member #: 8624
blue torch fab has them, http://bluetorchfab.com/store/produc...roducts_id=235.
beware if you opt for the whole DIY kit, i got the D60 and D80 kits, the fit was good on the d60 cover but the d80 kit is almost worthless because the welds along the ring won't leave enough room for the bolt heads, leaving me to have to modify their kit just to make it work.
__________________
96 Ram 2500 CTD 4x4, 5spd ext. cab, 270k miles, garage art under construction.
93 Ram W250 CTD 4x4, 5spd, reg. cab, 196k miles, tow rig in need of trailer.
February 8th, 2010, 08:23 PM
#3
Member #: 5979
Cant believe I forgot to look them up. COcummins how thick is your ring? They dont have a product spec on their individual rings? RuffStuff is 3/8". I notice with a lot of that mass produced shat you have to tweak it to get it to where its suppose to be
February 8th, 2010, 08:27 PM
#4
Member #: 8624
the rings i got were 3/8", i would guess it would be the same for the 14 bolt ring as well.
February 8th, 2010, 09:38 PM
#5
Member #: 14485
copperhead fab is probably the cheapest.
__________________
do your part and recycle, I'm pickling squirrels!
February 9th, 2010, 12:55 PM
#6
Member #: 5979
Quote:
Thanks buddy, just ordered it. What a deal!
February 15th, 2010, 10:29 AM
#7
Member #: 1781
Few few years ago I had more time than money and I looked into fabricating my own. Did some searching and it looked very easy. Depends on your time vs. $ ratio.
$0.02
__________________
TJ. "Homegrown" 4-link front and rear, D44's, 4.56 gears, locked, 35's, 9500i winch, front cage with stinger (& gunsight!).
"I heard Air Traffic Control was a stressfull job?"
-"Not at all; I'm not the one the airplane!"
February 16th, 2010, 07:45 AM
#8
Member #: 5979
Quote:
$0.02
Yea, but by splitting the money and time factors in half I decided to go with Copperhead Fab's for $50. Sweet cover and I dont feel bad about shaving the bottom 3 bolts off. Thanks for the pennies tho.
March 9th, 2010, 12:18 PM
#9
Member #: 5979
March 9th, 2010, 12:55 PM
#10
Your What Hurts?
Member #: 3374
I can't wait till I get my 2x2 torchmate. That $50 DIY kit is 10 pieces of 1/4" that in materials consumables and time is under $25. Look for a wrench by my name in the near future.
__________________
"Those who make peaceful revolution impossible
will make violent revolution inevitable."
March 9th, 2010, 01:16 PM
#11
Member #: 5979
This one was 8 pieces, the vertical strip thats about 2" wide and follows the path of the ring gear has 2 prefferated cuts that you bend.
Oh and you better hurry because I need a DIY cover for the D60 asap.
March 9th, 2010, 01:19 PM
#12
Your What Hurts?
Member #: 3374
As soon as they get the orders in front of me out of the shop.... They told me 5-6 weeks before I would see it at the house.
Were you able to bend that without a press brake?
March 9th, 2010, 01:27 PM
#13
Member #: 5979
The prefferation was a cut almost through the whole width of the piece, just put it in the vise and pulled, no heat.
March 9th, 2010, 05:40 PM
#14
Member #: 14485
Ended up looking good  I also have one on mine too. It's about as easy as they come for a DIY cover.
March 9th, 2010, 11:09 PM
#15
Member #: 5979
Thanks again for the heads up on it, ordering one for the front sixty tomorrow.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
