Yeah, there was a pretty good reason the trailhead wasn't packed. A little much snow and way too wet. Got past the 3 points area where Carnage meets up and one Jeep to the tight spot obstacle and the rest either got stuck or we turned them around...All of us turned around in the end. Way to slick...constantly digging.
Had 4 WJ's, 2 ZJ's, and 4 TJ's up there.
While backing down one of our guys in a WJ in an offcamber section had his front tire slide off...spent 2 hours recovering it.
A series of blocks and a winch did the trick:
Couple movies:
Myself
The WJ stuck earlier
Another WJ with some bad tires...enough gas helps that![]()
