Decided to go a different direction with the hydraulics on my 57 project.
Pics here: https://cosprings.craigslist.org/hvo...588252156.html
Chassis- 115"x 33 3/4"
2 cylinders
PTO unit- Chelsea A2HNW
Pump
PTO drive shaft, pivots and brackets
Old lines
2wd SM465
The chassis is made from 3/8" 3 1/2" angle, the gussets are 3/8" and the ram mounts on the reservoir are 1/2" steel. This thing is beefy, the pistons on the rams are 2 1/4" dia.
I'm guessing the whole thing weighs around 1500lbs.
Perfect if you want to build your own 6-8 ton dump truck.
$650
