Results 1 to 25 of 25
    Dec 2001
    Littleton
    Project NO UNDIES
    Dragged this home yesterday.
    1969 Jeepster Commando
    V6, manual, full top and doors
    The trash and spiders were included free of charge.
    Dragged onto trailer with four flat and frozen tires ( no fun). Got some cheapies from les Schwab scrap pile to get it in the garage.
    Debating getting it running as is our swapping my yj guys over, will device as cleaning ensues.
    Thoughts?
    Sent from my LG-H910 using Tapatalk
    90 YJ - Vortec L31, TH400, NP205, hp44/14bolt, 108" on Leaf Springs. 40" MT2s on Raceline Beadlocks
    looks all original. If you're flipping it, then keeping it original should command the highest $$.
    Dec 2001
    Littleton
    Plan for now is to see if motor turns and if I can breath some life into it. The original owner filled me in on some fun facts that he thought were important:
    1. Ran when parked (circa mid 90s)
    2. New brakes
    3. New clutch
    4. Tires were new when parked
    5. Seats registered twice while it sat
    Now I know none of that means anything but it was fun to listen to him chat about it.
    Gonna order a carb kit and clean under the hood, hit the cylinders with some mystery oil and try to turn by hand. See where that gets me. If its got any compression I will order some tune up bits and try to get it running. If not, will figure out my next steps from there.
    THE STRANGER's Avatar
    Mar 2006
    United Republic Of Saudi Aurora
    Wow, great find...
    2 OF THE VOICES IN MY HEAD SAY THE WORLD IS A BEAUTIFUL PLACE. THE THIRD KEEPS YELLING PULL THE TRIGGER.
    EVERY TIME YOU KEEP YOURE MOUTH SHUT SO YOU DONT OFFEND SOMEONE YOU LOSE A LITTLE PEACE OF YOURE 1ST AMENDMENT RIGHTS !!!!!
    vb's Avatar
    Sep 2002
    montrose
    Gregg berry at 4wd extreme in Longmont is a great resource of information for those.
    " Every soul deserves a shot at a Cadillac, but not everyone should be guaranteed a Cadillac". Ben Stein
    Dec 2001
    Littleton
    So its looking very likely that I may sacrifice it to save all my YJ parts, which may be a shame to a purist. If anyone wants to save it from me before I hack it up you have a couple weeks before I make a firm decision.....
    Quote Originally Posted by mines4x4 View Post
    Am I reading that correctly? :-/
    Dec 2001
    Littleton
    Maybe, the wife switched gears and is now freaking out about having two. So I either sell the YJ, sell this, or combine the two.
    I sorta hate the idea of only using the tub from this and selling the rest, but 'happy wife' and all. Like I sad, there's time if someone wants to come get it, I'm only going to be cleaning and investigating for a few weeks still.
    Plus the tub would get another lease in life and my yj would mostly get to stick around and with room for the kiddo now. Decisions decisions.....
    Mar 2006
    Did I hear YJ parts for sale ?
    Dec 2001
    Littleton
    Potentially.... Or an entire YJ. Check out the rigs/buggies for sale section. Also have top and doors for sale regardless of what happens
    Mar 2006
    Just soft top door surrounds..
    vb's Avatar
    Sep 2002
    montrose
    Half doors?
    Mar 2006
    Long story but, have the hall doors soft uppers.
    But he used side by side top and back panel.
    If I can find surround I can seal off the cab a little better.
    Nice Barn find.
    Red 1st gen 4Runner, White Buggy
    Dec 2001
    Littleton
    Thx.
    Continued cleaning and disassembly last night. The plan for now:
    Mount commando tub to my YJ Crawler
    Keep YJ hood and grille for now to minimize how much fitting needs to happen
    Since the commando floors are toast it works nice as the 205 in my YJ is clocked flat and needed a lot of floor removal anyways to fit.
    Will try to match firewall locations as close as I can
    Get the body mounts as close as I can
    Once its wired back up and running again, first stop is cage to tie it all together, this time with a rear seat for my kiddo
    Rolling chassis will be for sale:
    225 v6, t86, dana20, close knuckle dana 25, dana 44 rear
    Mar 2006
    Sounds like it will be one he'll of a crawler...
    I'll f s allow the build.
    Dec 2001
    Littleton
    Lots of cleaning and dismantling.
    The wife is a huge fan with top gone.
    Broke or had to cut off almost every bolt. Got all the body mount bolts off, steering unhooked, and just need to get the last few bits then the body comes off.
    Gonna be a fair bit of floor panel repair.
    Once the tub swap is done hoping to take it to Addicted Offroad up north.
    Dec 2001
    Littleton
    Really digging the roadsters look, it may never get the hardtop reinstalled.
    Measuring between this one and my YJ, the tub to windshield is 3ish inches shorter, and I had initally thought I could end up with overall shorter vehicle.
    However when I flat clocked my 205, the floor intrusion was massive, so I may mount this one 3" higher to improve floor layout. Once the cage is installed its a moot point. Floor plan layout was one of the things I regretted on my YJ. Will see how it looks as I move stuff over.
    Mar 2006
    Sounds like this will be one hell of a ride
    Always did like the top off look of these
    Dec 2001
    Littleton
    Got the scrambler set on the YJ frame. May push it back a bit to clear the firewall and lose some height at the same time.
    Currently have 6" cribbing under the body mounts and the windshield is the same height as my yj was, 81". Hoping to lower at least 2-4 inches. But also dont want a fully hacked up drivers floor.
    Also debating paying a shop to do the body mounts when they do the cage. But need to get some quotes.
    vb's Avatar
    Sep 2002
    montrose
    Like
    And then?
    CJ/buggy,FI406,465,205,D60,14boltFF on beadlocked 39.50 swampers.See build.
    http://www.colorado4x4.org/vbb/showthread.php?t=134201
    '70Jeepster, 225,T-14,D20,10bolt,12bolt on 34/9.50/15 Swampers
    www.tubebuggies.com
  24. #24
    vb's Avatar
    Sep 2002
    montrose
    Good point...
  25. #25
    Dec 2001
    Littleton
    Progress has been slow.
    Got the body mounts mocked in. Most of the wire runs are in but needs lots of cleanup. Fired it up enough to move it into the other bay so wife can use her side for the winter.
    Was able to salvage a lot of pieces from tbe YJ. Right now it has the whole pedal assembly, booster, and steering column from the 90 as well as half the flat dash I has made before. Might try to steal the yj inner fenders for the stambler too as they are nice and square and the round ones dont work with the stretch and 40s anyways. Have a cool plan for the factory flares on this thing too, stay tuned for that.
    Not a lot of pics right now.
    Winter plans are:
    Finish replacing front floorboards
    Mount seats
    New injector spider (updated)
    Jeepster fender and grill
    Finish wiring and dash (may switch to tablet instead of autometers, still on the fence here)
    Let me clean garage and snap some photos
