Page 2 of 2 FirstFirst 12
Results 41 to 50 of 50
  1. #41
    Still following! Thanks for the update!
  2. #42
    Colorado_Baja's Avatar
    May 2006
    Coloradical Springs
    Went out to Hugo and got another front clip, hopefully I can turn 2 busted ones into one good one..
    20180321_104755 by colorado_baja, on Flickr
    More on that later.
    Cut the van body off this weekend, still runs and drives!
    20180325_171943 by colorado_baja, on Flickr
    Didn't go exactly as planned.. I got super lucky and managed to not smash the glass out of the back doors some how..
    IMG-0023 by colorado_baja, on Flickr
    Normally I wouldn't care about the glass but I wanted to save the back half to use as a redneck storage container for the duration of this project. Gonna pop rivet some sheet metal scraps to the bulkhead to fill in the gaps and foam/caulk the crap out of the rest.
    20180325_172034 by colorado_baja, on Flickr
    197? DJ-5 LHD & 4wd
  3. #43
  4. #44
    May 2006
    Coloradical Springs
    Finished my redneck storage unit and filled it full of stuff. Still need to do a couple things to it but its kept everything dry through rain and snow.
    20180424_140818 by colorado_baja, on Flickr
    Pulled the van in and got rid of the rest of the body.
    20180423_163040 by colorado_baja, on Flickr
    Hung the trans and T-case so I could see where the new trans x member needs to be. Trans x member and front drive shaft are going to clear the ABS pump so that's a bonus.
    20180425_171622 by colorado_baja, on Flickr
    While I was cutting stuff today I torched the body mounts that are going to interfere with setting the cab on there.
    20180425_171635 by colorado_baja, on Flickr
    20180425_172114 by colorado_baja, on Flickr
    Going to finish the mounts for the new trans x member tomorrow and get ready to mock up the cab.
  5. #45
    Your storage idea has me wondering if you shouldn't put a hitch on the front of it and axle under it and sell it as an ATV trailer when you're done. Deep enough?
    Everything looks like it falling into place nicely!
  6. #46
    tacotoy's Avatar
    Apr 2005
    Westminster
    I am excited to see the body go on, even the test fit and everything to work on body mounts. Awesome project!
    hookers and blow!
  7. #47
    May 2006
    Coloradical Springs
    Funny you should mention that.. Ive been looking at $2-300 truck bed trailers on Craigslist off and on. If I set it on a trailer frame and had it tagged the city couldn't say anything to me if I wanted to keep it at my place in town to store junk.
    It might be a little small for an ATV but you could definitely get a motorcycle or two in there on rails. I didn't really close in the front with the idea of it going down the road but the window I put in the front is 1/4" laminated safety glass I had left over. Even if it took a rock it wouldn't explode. I also have keys to the back door so it locks too.
  8. #48
    May 2006
    Coloradical Springs
    Quote Originally Posted by tacotoy View Post
    Thanks, me too. Getting the body on so I can do cab mounts is what I'm pushing for right now.
    When I get the drive train hung, body mocked up and it rolls freely on 4 wheels that will be a big milestone for me. Still going to be a lot to figure out and do but thats going to be awesome.
  9. #49
    May 2006
    Coloradical Springs
    Been busy doing other summer stuff..
    IMG_1068 by colorado_baja, on Flickr
    But I have managed to get some work in on this project..
    Made a trans x member.
    20180427_165817 by colorado_baja, on Flickr
    20180427_165828 by colorado_baja, on Flickr
    Made some new frame mounts for it to sit on.
    20180719_110321 by colorado_baja, on Flickr
    Had to come forward and down a bunch to accommodate the NV4500 and still have a reasonable rear angle on the drive line.
    20180719_110305 by colorado_baja, on Flickr
    Bolted up.
    20180719_140547 by colorado_baja, on Flickr
    Got the driveline shortened and balanced here in town.
    20180719_140514 by colorado_baja, on Flickr
    Finally got to set the cab on there to see how it looks.
    20180804_121552 by colorado_baja, on Flickr
    20180804_161440 by colorado_baja, on Flickr
    Had to bob the front frame horns to slide it far enough forward to look right.
    20180813_135926 by colorado_baja, on Flickr
    20180813_135938 by colorado_baja, on Flickr
    I think with the smaller 3800 fenders and a taller tire it will look sweet!
  10. #50
    You can't underestimate the time spent with your kiddos! That is the wisest of investments!
    Truck looks great!
