    Threadlock Beadlock?
    So first time dealing with non split rim beadlocks. Should I have used some blue thread lock on the hex bolts? Nothing mentioned in the instructions but seems like the bolts would just come out pretty easy. Feedback?
    Red 1st gen 4Runner, White Buggy
    what bead locks?
    I run DIY for now and they have a lock nut on the back and I have to check them once a season to make sure they are all tight...there is all ways a few lose.
    Got some spyderlocks 24bolt 17"
    I wouldn't use threadlock. I use anti-seize on my aluminum wheels with steel bolts. The bolts do have lock washers though.
    Longmont
    No threadlocker. Just use the correct hardware and properly torque each bolt, and recheck often.
    Mine are aluminum Champions and I recall there being a ft/lb setting. I followed that and haven't touched them in years! But I don't know what that spec was.
    I too say NO on threadlock.
    Edit to add from their FAQ page:
    QUESTION: What should I torque my Spyder lock bead lock rings to?
    ANSWER: 25 lbs. is the recommended torque specification for the clamping ring. More torque may be required for tires with thicker beads. 25 lbs. should always be your baseline, and then tire and wheel should be checked for a good even seal. If more torque is required, you should NOT exceed 35 lbs.
    ** Blue lock-tite is always recommended on bead lock ring mounting hardware
    ** 25 lbs torque is in reference to the clamping ring, NOT the lug nuts for mounting the wheel
    ** Over torquing the bead lock clamping ring will fatigue mounting hardware and may cause a failure
    ** Final torque should always be checked by hand, and not with an air or electric impact tool
    Oh and you're welcome!
    Good info, thanks everyone!
    Quote Originally Posted by Aaron View Post
    this!
