Page 11 of 12 FirstFirst ... 9101112 LastLast
Results 401 to 440 of 464
Thread: Project 2.0
  1. #401
    So I gave up on the 4 link again.... running out of time do get this thing up and going for wheeling season.
    So the 3 link is fully welded in place, made new rear shocks mounts for the air shocks, mounted the new trans cooler behind the passenger seat still need to plum it and wire it... got new Yukon u joints put in ,new axle tube seals and repack all the bearings.
    One other little piece showed up!
  2. #402
    IMO nothing wrong with a good 3 link set up. Congrats on the Atlas, what made you decide a 5:1 ? Looks a lot different than my old school Atlas.
    Red 1st gen 4Runner, White Buggy
  3. #403
    Quote Originally Posted by Nimbus View Post
    Yeah for sure!!! The swing of the 3 link has some defaults and the only reason I wanted to swap it out was to get 2.5Ē coil overs and with the swing I canít fit them. As for the atlas I went back and forth on a 4.3 and the 5.0 but end the end I donít see me getting a v8 and if I ever build a different buggy it will be a turbo 4 cly.
  4. #404
    Don't those beers get kind of hot?
  5. #405
    Quote Originally Posted by newracer View Post
    Iím sure of that
  6. #406
    Got the atlas in yesterday and remade the carrier bearing mount everything clears at full bump Iím going to pick up engine hoist today to help cycle the suspension safer then the high lift.
  7. #407
    Picked up a engine hoist so I can check clearances And itís tight but there is 3/16 gap under the drive shaft and link cross member. Time to weld in the rest on the links and work on skid plates.
  8. #408
    Nice! Looks like you are getting there! Im sure with everyone wheeling there is no pressure to get it done lol!
  9. #409
    Haha right!!!! But I am on the home stretch of things that Iím going to complete this go around
  10. #410
    Very cool, I'm sure you will be happy with it.
  11. #411
    Yep! The only thing im unsure of is the air shocks... Iíve had them before and I was a little to big for the 2.0s back then but I ran out of time and money for coilovers and the 200 I paid for the air shocks will have to do for a bit.
    Got most of the rear suspension welded up tonight but ran out of wire so hopefully tomorrow Iíll be able to pick some up.
  12. #412
    Spent some more time welding last night and did some painting but nothing photo worthy....
    Down to welding shock tabs, one more gusset, drive shaft bearing mount and building my skid plate.
  13. #413
  14. #414
    Longmont
    When are you taking it out for the first time?
  15. #415
    I have seen some gnarly rigs run air shocks before with great results. Can't wait to see the finished "new" rig!
  16. #416
    Hopefully with inThe next month just a few more things left!
    Re seal the rear diff
    Fill both diffs
    Build a new skid plate
    And put the floors and seats back in
    Charge shocks
    Ya they can be great And same man!!! Getting closer finished welded just about everything else last night
  17. #417
    Got somethings done today on the buggy after a bunch of clowns stopped bye last night making me want to get done sooner.
    Changed the oil
    Put springs on the coilovers need longer springs now
    Finished the oil pan skid plate mount- still waiting on the metal for the rest of the skid plate
    Installed the rear shocks
    Made tabs for a rear limit strap
    Topped off all the fluids
    Even started it up to make sure everything still works
    Start on a better radiator mount
    As soon as the skid is done I can start putting everything back in this pos. Nothing to fancy to show
  18. #418
    Jun 2005
    Colorado Springs, CO
    Well if you would quit wasting time posting pics this build would be done. Lol.
    Good seeing you this weekend. Build is looking great.
    03 Rubicon TJ, needs work.
    https://m.facebook.com/ClownsInc
  19. #419
    Quote Originally Posted by Chris Halvorson View Post
    Ya I know hahaha! And itís always good to see me!
  20. #420
    Got a few things done last night....
    Replaced a fuel line as it developed a leak and the it decided to blow up so it got a steel breaded line.
    worked on the top half of the new radiator mount but needed to get some all tread to wrap it up.
    Bolted up the uhvm boat sides.
    Unbolted the 14 bolt cover and found a nice little surprise The adjuster holder and bolt decided to come out and play vs saying in play so Iím going to pull the ring and pinion out and check them along with the barings for Damage but I think it will be good to go
    Got my new skid plate made as well
  21. #421
    Pulled the ring gear out and nothing was messed up so Iím just cleaning everything really good and Just send it.
    Finished the radiator mount and started the skid plate last night will try to get photos once things are a little closer to done
  22. #422
    Oct 2012
    Thornton, CO
    Looks great Jared! Congrats on the Atlas.
    Partially Erect YJ
  23. #423
    Quote Originally Posted by WideJ View Post
    Thanks man!! Should have cut this all out when I built this thing...... oh well.... lol
  24. #424
    Got a few hrs on it yesterday rebuilt the rear axle and got the skid plate close to being done just need to add an extension to protect the drive shaft bearing mount, I donít think I may need it as itís all above the frame but Iím going to do it just to be safe
    But down to a small list of to dos
    Drain and fill the coolant
    Change springs and charge all shocks
    Finish up the shifters
    Replace a u joint in the front drive shaft
    Fill the rear axle up
    Grease the front axle u joints
    Install the interior
    Go wheeling
  25. #425
    I like the last one
  26. #426
    I like the last one
    Me too!
    Got a few things done last night- skid, shifters they may need some adjusting but we will see, drive shaft u joint
    The New flat belly
  27. #427
    Looks great. Did you add any type of support inside skid plate? Mine is similar to yours and even being 1/4 in it got a bow in it pretty quick, and I don't hit the same level trails you do. I put a couple of pieces of angle on the inside and it hasn't moved since. I also added strap on the front and rear edges to keep them straight. It's stupid heavy.
    If it weren't for bad luck, I'd have none at all.
  28. #428
    Quote Originally Posted by Mickey*B View Post
    Well itís resting on both cross members both frame rails but with no backing plates Iím sure it will still been or self clearance it self
  29. #429
    Been chipping away on things got all the interior put in except the pass seat so I can adjust the shifters, had to re seal the rear diff for some reason Iím pretty sure some gear oil f-ed that up so I re cleaned it and resealed it last night, greased the front U joints, greased everything I could.
    Need to add oil and change the shocks so I can test drive it
  30. #430
    Getting closer! Hey where did you get that velcro storage thingie that's strapped to the side there in the last pic?
  31. #431
  32. #432
    Yeah really close... too bad I had to spend all weekend in Denver or I would have been driving it!
    I got mine from ruff stuff but I think they stop selling them... I would just look for utv bags and youíll find something that will work for you!
  33. #433
    Quote Originally Posted by rollingblubber View Post
    Yeah really close... too bad I had to send all weekend in Denver or I would have been driving it!
    Other options
    https://www.amazon.com/s/ref=nb_sb_s...d=NFWE3BGLRG1A
  34. #434
    That works!! I wouldnít spend a lot on them they seam to be pretty beat up from rocks.. I rip the Velcro off on them all the time lol
  35. #435
    This is the one that looked the best to me. Also will fit one of my opening perfectly.
    https://www.amazon.com/Ibera-Bike-Me...70_&dpSrc=srch
  36. #436
    Much cheaper then atv utv bags
  37. #437
    I am very sorry for that. I hate it myself.
    Mike, I like those bags but wonder if the strap would be long enough to go around the tube of a buggy.
  38. #438
    They have a width of 1.7" and 1.9" so I assume the strap would fit.
  39. #439
    Did a coolant flush, charged the shocks, filled the rear diff., the buggy is about 1Ē higher the n I want it but weíll see if it settles down
    Just need to fill a tire up and go for a drive.
  40. #440
