Page 13 of 13 FirstFirst ... 3111213
Results 481 to 513 of 513
Thread: Project 2.0
  1. #481
    Had to strip the old motor down to get the converter and flex plate off... found broken rod parts in the pan was cool in a way but still stings all at the same time! Going to have to rewrap the exhaust as everything is oil soaked but this gives me a chance to change my exhaust up some!
  2. #482
    cheftyler's Avatar
    San Jose, CA
    Ouch! I'm no mechanic, but I don't think there should be a winder in that spot.
  3. #483
    Quote Originally Posted by cheftyler View Post
    Itís optional and super rare they should never ran or looked at...... best left on the stand under a glass case!
  4. #484
    cheftyler's Avatar
    San Jose, CA
  5. #485
    vb's Avatar
    Sep 2002
    montrose
    Progress!
  6. #486
    Still working away on this little bit at a time.... took two hours just to get it bolted up so maybe it will be a runner soon!
    Wires and stuff is everywhere!!!!!🤮
  7. #487
    Woohoo more progress! Stay with it! It will be done before you know it.
  8. #488
    For sure!!! Just been staying busy help a buddy build a new rig a few nights a week knowing that mine doesnít need much!
  9. #489
    Got the exhaust shortened and less complicated ran most of the wiring and finished bolting up the TC and other odds.
    Going to wrap the exhaust next and install the intake/exhaust and test fire it!
  10. #490
    Wow! Great progress! Bet the excitement is starting to build
  11. #491
    Closer!
  12. #492
    Well it runs.... need to chase down the high idle issue and a few other things but itís closer...
  13. #493
    Runs!!! Congrats! Major milestone.
  14. #494
    Awesome!
  15. #495
    Thanks guys... have had a few rough days with the wifeís Heath so havenít had much time to dig in to this more.... hopefully Iíll have some updates soon
  16. #496
    Got a min tonight to check out the high idle... I need a new intake gasket that Iíll pick up from jeep tomorrow but it seams to be running well!
    Button up a few lose ends on the front axle why I wait until tomorrow... need to pressure wash the radiator there is a lot of mud on the bottom half behind the winch before all that goes back in
  17. #497
    Well had a set back on this..... ended up walking away from it for a few days to get my head back on straight, trans came back out found that there was a bushing in the crank of the new motor that wasnít in my old one and some how I over looked it and it was causing me headaches! I tried everything to get it out and it wouldnít even think about moving (packed it with grease= just made a huge mess, tried a bearing puller with a slide hammer= it just pulling some material and not moving the bushing, tried hitting it with an air hammer = got no where)
    Finally just started cutting the 🤬 thing out and it came out! I now have the trans back in and tcase but Iím taking the weekend and running down to Moab with the Tacoma to get some much needed time behind the wheel!
  18. #498
    That sucks. Have fun on Moab.
  19. #499
    Had a fun time down in Moab wished we had more time but good news itís just 2 hrs away.....!
    Other news worked on the buggy and got it running again and it looks like I fixed the grinding issues I was having.
    With that fixed I started working on cleaning up some wiring and trans cooler lines and started putting some odds and ends back together (not much that is photo worthy).
    Things todo still:
    Rebuild the one air shock thatís blown- seals on order
    Order and replace steering orbital and bleed air
    Replace a bushing on the gas pedal that broke - part on order
    Want to make a small firewall that covers a spot to block some hot air thatís blowing on my feet
    Need to pressure wash all the oil off things before putting all flooring and seats back in
  20. #500
    Oh man free parts........!
  21. #501
    Free sd front??? Score!
  22. #502
    The Man With The Plan's Avatar
    Aug 2001
    Arvada, Crawlorado
    One of the perks of working for a Ford store, eh?
    Sent from my SM-N950U using Tapatalk
    Jon, AKA The Man With The Plan, ΜΟΛΩΝ ΛΑΒΕ Illegitimi non Carborundum = "Don't let the bastards get you down" Micris Fidelis="Faithful to small things" And it's an anagram...I'll let you figure it out
  23. #503
    Yes it is!!!
    Quote Originally Posted by The Man With The Plan View Post
    Yep!! 👍
    It comes with some issues.... but Iíll cut the Cís off it and toss the center section
  24. #504
    vb's Avatar
    Sep 2002
    montrose
    Only using the knuckles?
  25. #505
    Quote Originally Posted by vb View Post
    Yeah along with other odds and ends but the rest of it is trash
  26. #506
    Yes it is!!!
    Yep!! 👍
    We used to make high pinion rears out of those center sections.
  27. #507
    Quote Originally Posted by Jeep-in-dna View Post
    For sure!! My boss has one that heís working on but If this wasnít bent/ crack in the housing it would be saving.
  28. #508
    Had a good shake down run
  29. #509
    Nice dude! Congrats on getting back out!
  30. #510
  31. #511
    Thanks guys got some odds and ends to fix but it was a fun day
  32. #512
    Few more pics
  33. #513
    Picked up some more free parts today to add to my some day rear steer or whatever stock pile
