Page 10 of 10 FirstFirst ... 8910
Results 361 to 400 of 400
Thread: Project 2.0
  1. #361
    Congrats on the new place!
    As far as photo hosting, just use google. Free, great editing software, and VERY easy to use.
    Thanks! So much room for activities!
    Awesome Iíll check it out
    Quote Originally Posted by Short Bus View Post
    Sounds like you just need an Atlas 4!
    Haha no Iím good lol! I really donít have space for a longer t-case on the other hand turbo could make up for wheel speed lol!
    Also, Don't delete your photobucket pictures. There is an extension in the Chrome store that "fixes" the photobucket sabotage. If you use chrome, you can still see the images.
    I havenít tried that fix yet....
  2. #362
    Sounds like a decent laundry list of things to do. Sorry to hear about the 300M problem , that is rather untimely. This will be my second rig with a Atlas in it. My first truggy had a 4.1 (or was it 4.3?) it was a long time ago, and my new one has a 3.8. The numbers don't seem that far apart but there is a difference on the trail for sure.
    Oh and I use Imgur for hosting, tried google but half the people could not see my pic's .
    Red 1st gen 4Runner
  3. #363
    Longmont
    Quote Originally Posted by Nimbus View Post
    You need to make sure the photos in Google are shared. Once they are, you are good to go. Been using them for years now with no issues
  4. #364
    yeah it is! working on the Belly is my number one priority and im sure that will take up most of my time and im really looking forward to the atlas
  5. #365
    Cool, you going with the 32 spline upgrades and flanges?
  6. #366
    32 splines for sure, I may just keep with the 1350 yokes to hope drive shaft changes are little to none but I may go flanges as they seem to be a little faster to change out the drive shaft.
  7. #367
    bluexj's Avatar
    GJ/ Cheyenne
    Go flanges much stronger. I was blowing yokes up now no problems after switching to flanges. Lots more beef if you had both in your hand I had to change seals because the flanges are thinker around the splines.
  8. #368
    Quote Originally Posted by bluexj View Post
    Umm ok cool Iíll check that out
  9. #369
    Short Bus's Avatar
    Oct 2006
    Arvada
    Jared, what wheelbase did you end up at on your build?
    You happy where itís at?
    '01 "Cherokee" - Kind of.... (Jeep: Steering Column, Firewall, Partial "frame", Brake Booster,and a Little Sheet Metal)
  10. #370
    I'm at 110" and pretty happy with it don't really see me changing it anytime soon. most everyone I wheel with is 105-114 and the 105 is a little short and really need water to help on big sh*t... the 114 is a little long but front digs help lot.
  11. #371
    Short Bus's Avatar
    Oct 2006
    Arvada
    Iím was right at 110. I think the font axle will sit in a really nice spot in the new engine if I push it out to more like 112. Im trying to decide if thatís too much length for 38s. Iím hoping this will be the last time I rebuild the front end.
  12. #372
    are you planning on going bigger tires? how's the approach and departure angles? but again if everything fits it I would just... send.... it!
  13. #373
    got a chance to work on the buggy a little last night... and good thing I am going through things... found that I had no bolts holding the trans to my cross member and I cracked the cross member as well... oops lol
    anyways the T case is coming out tonight or tomorrow then I am going to cut about 3ft of the TJ frame out on each side and replace it with 2x4 3/16 and I should be about to suck it in like 3" on each side.
    anyways ill get some pics once I start cutting
  14. #374
    At least you are finding this stuff now rather than on the trail!
  15. #375
    Right!!!
    Worked on the buggy again last night, got the t-case out, cut the drivers side frame out. I did take a measurement at the widest point and it was 42.5Ē.
  16. #376
    Dang timing, If I had the $$ I'd take that 300 for my 4runner project.
  17. #377
    well if it doesn't sale maybe timing will work out lol
  18. #378
    Well decided too take more of the frame out and go past the front link mounts I would have took the last 2 ft out but that a lot more work with motor mounts and shock hoops and so on... so itís staying... for now lol so why I did this is because the frame straight in this area vs where I 1st cut it was still kicked out some
    I did get the new frame rail fitted up and built a new rear upper link mount but for got to take a photo of that!
  19. #379
    Got the frame weld in place tonight! The frame is in 4Ē so over all Iíll be in 8Ē from the factory!!! I still have a long ways to go!
  20. #380
    Sweet, you having any clearance issues on the inside narrowing it that much?
    '94 YJ- 5.3, 4L60E, 241, 60, 14, 107", 42"s
    '09 LMM- H&S, deleted, red in color & tows shit
  21. #381
    Quote Originally Posted by MDert View Post
    so far no.. the pass side will be a little more work to fit the t-case, battery, and 2piece drive shaft mount but knock on wood!
    you'll have to come by and tell how im doing it wrong and drink my girl beer! lol
  22. #382
    Haha sounds good I like all kinds of cold beer! You gonna need a 2-piece driveline with the atlas?
  23. #383
    lol ok!
    and not really sure most likely to still clear the starter and I all ready have one so why not keep it
  24. #384
    oh and I would like to fit a 4link up there but we will see... lol
  25. #385
    Looking good!
    Sent from my iPhone using Tapatalk
  26. #386
    Driver side is getting closer, I have to redo the rear upper link mount but I have a game plan for that! I cut the old mount off and tack it where I think it will end up at
  27. #387
    Getting it together! Bet you'r liking that new garage!
  28. #388
    Slowly lol but ya Iím love it .... itís nice to have room to work around things set stuff up to fab a part and then keep it there until the next one
  29. #389
    T case sold today so now I need to shop for an atlas!!
  30. #390
    Short Bus's Avatar
    Oct 2006
    Arvada
    Sweet! Shiny new parts coming soon!
  31. #391
    Dang it! and Congrats! Are you looking for new or slightly pre-owned?
  32. #392
    If you're looking for new I was quoted a decent price from skinny pedal racing on pirate. I'm looking for used myself, budget wise, but will likely end up going new from skinny pedal racing if I can't find a good used one soonish.
    The buggy is looking great! Should be some good upgrades you'll appreciate.
  33. #393
    Yes I canít wait!!!
    Lol thanks! Most likely just going new as the used ones tend to cost 2k and still need something to work for my set up... but Iím looking
    Quote Originally Posted by crawlercreations View Post
    Awesome info thanks man and yeah Iím looking forward too it!
  34. #394
    I gave you my guy's info at Black Label... best deal I could find when I went shopping for mine.
  35. #395
    Quote Originally Posted by bustedcrawler View Post
    For sure!!!!
  36. #396
    Let us know whatcha get!
  37. #397
    Well do!! Waiting on a few quotes to come back!
  38. #398
    Got the other side cut out tonight and tack the the new rail in place and took a measurement to see what I ended up at.... it came out to34Ē.
  39. #399
    Got my atlas on order!!!! Ended up ordering a 5.0
  40. #400
    Still working on this thing had the front suspension done with a 3 link but a buddy was over and we dropped it to full bump and we are pretty sure I can get a 4 link in there.... so Iím now working on that.
    Sold my front coil overs to hope to get some 2.5s coil overs up front down the road, ended up finding a deal on some air shocks so for now I am going to move the rear 14Ē shocks up front and up the air shocks in the back until funds for 2.5s later down the road.
    The rear suspension is tack up waiting for my atlas to get here to check clearances for the rear drive shaft, trans cross member is tack up again waiting on the atlas to check clearances, all the flooring mounts are welded in... I think Iím getting closer but the list is still long
