April 20th, 2011, 02:51 PM #1
- Join Date
- Apr 2010
- Member #
- 19746
Help school me on what my D44 axles need please!
I'll try and keep this brief. I'm stuck at a cross roads with my TJ build and need advice from the experts.
Currently I have an 06 TJ Rubicon SWB. It's got a 2" coil spacer lift with RS9000 shocks, a 1.25" JKS body lift and a 1" MM lift. I'm running 285/75R16 tires on the stock Moab wheels with Spidertrax spacers. Everything is great and I have no vibes or DW to really speak of. I don't DD the Jeep very much. It only gets 3500 miles a year and I'm light on the throttle but it seems a lof ot trails.
My next step is to install UCF ultra high clearance skids and a Savvy gas tank skid, along with a new driveshaft, adjustable RUCA's, Currie trackbar relocation bracket, and new BDS 2" lift coils to get rid of the spacers and sagging stock coils.
Now comes the fun part. I'm toying with the idea of going to 37's with the help of Metalcloak fenders and that's where I need some advice. What to do about my stock D44 LP axles.
I know I'll need upgraded shafts and a regear, so I was thinking of getting RCV front axles for strength and to eliminate binding and some chromoly rears. After that I'm not sure what to do. I've read that I should sleeve and/or truss the tubes to keep them from bending. I've read that the D44 R&P will now be the weak link in my axles so I'm considering the Jana K4 kit. And I've heard the knuckles and maybe even the axle end C's are weak for 37's.
So what do I really need and what's overkill? And what have I missed?
April 20th, 2011, 08:36 PM #2
Truss the front and don't look back
Clean 1986 4Runner, I've joined the dark side
April 21st, 2011, 10:00 AM #3
- Join Date
- Jul 2010
- Member #
- 20435
Upgrade to a D60 before you spend too much money on your 44.
April 21st, 2011, 10:02 AM #4
What kind of trails will you be running? Do you like the skinny pedal?
April 21st, 2011, 10:07 AM #5
I'm in this boat too with my 2010 JK. A D60 is EXPENSIVE even if it's used so the best and most affordable thing I have found is: inner C gussets, and a nice Truss for the long side, then put in inner sleeves. There are plenty of other options but so far this is the most affordable.
2010 Rubicon on 37s
with custom placed dog hair
April 21st, 2011, 10:10 AM #6
JK axles and TJ axles are way different.
the TJ rubicon can take the 37's with chromos and truss easy.
April 21st, 2011, 10:29 AM #7
- Join Date
- Apr 2010
- Member #
- 19746
Thanks for the advice. So there's no worry in the strength of the R&P or should I look into the Jana K4 kit?
I'm very easy on the throttle in the rocks.
April 21st, 2011, 10:39 AM #8
the stock lockers suck also.
April 21st, 2011, 01:55 PM #9
- Join Date
- Apr 2010
- Member #
- 19746
Yeah I heard they like to go boom.
school me on these axles! jumping from d30 to d60 or 70
By rgeiser in forum General 4x4 DiscussionReplies: 39Last Post: December 16th, 2008, 03:12 PM -
school me on toyota axles
By DANGERRANGER in forum General 4x4 DiscussionReplies: 9Last Post: October 14th, 2008, 08:00 PM -
Width of Wagoneer Axles vs. 'Wrangler' Axles
By Jim B in forum General 4x4 DiscussionReplies: 10Last Post: June 17th, 2004, 07:25 AM -
axles
By CJesse7 in forum General 4x4 DiscussionReplies: 19Last Post: May 4th, 2004, 08:56 AM
Buena Vista memorial...
May 23rd, 2013, 06:13 PM in Trail Talk
