Results 1 to 22 of 22
    JK ABS Bleeding W/O Scan Tool?
    Before I submit my poor JK to the same dealer whose tech left the oil filter loose last time they serviced it, does anyone know how to bleed the ABS system without Chrysler's DRBIII Scan Tool?
    1BADKJ's Avatar
    Feb 2007
    Colorado Springs CO
    You can not do it with a DRBIII anyways,you need the StarScan for the JK.Otherwise there is not alot that can be done,you can try going out and slamming on the brakes hard enough to engage the ABS(need to do about 5-10 times) and then re-bleed on the spot as air will enter the ABS pump again if you drive back home.This has worked a few times on older ABS systems but never got it to work on newer ABS systems though.
    '02 KJ,SkyJacker lift,ARB in rear,Detroit TT up front,and a custom paint job.:P
    What exactly does the DRBII tool do during its routine? Is it possible to pressurize the MC and bleed the 6 lines right at the ABS unit?
    1BADKJ's Avatar
    Feb 2007
    Colorado Springs CO
    Quote Originally Posted by SoK66 View Post
    The DRBIII is pre-'05 Chrysler vehicles.
    The StarScan cycles the ABS system to purge any air in it.
    THE STRANGER's Avatar
    United Republic Of Saudi Aurora
    Why ??????????
    2 OF THE VOICES IN MY HEAD SAY THE WORLD IS A BEAUTIFUL PLACE. THE THIRD KEEPS YELLING PULL THE TRIGGER.
    EVERY TIME YOU KEEP YOURE MOUTH SHUT SO YOU DONT OFFEND SOMEONE YOU LOSE A LITTLE PEACE OF YOURE 1ST AMENDMENT RIGHTS !!!!!
    Unless you replaced the ECU/HCU its a sealed system
    Just a normal bleed
    Nornal bleed is with a vacuumm bleeder
    Quote Originally Posted by THE STRANGER View Post
    Just a normal bleed
    This...
    normal brake work like changing calipers, hoses etc...just bleed it like a non abs.
    tantonio's Avatar
    Nov 2007
    Centennidull/Littlefun
    Or you could have just kept your YJ....
    Unless you replaced the ECU/HCU its a sealed system Just a normal bleed Nornal bleed is with a vacuumm bleeder
    When we changed the brake lines last year the reservoir got low enough to get a bit of air into the ABS unit. The front lines dump fluid like the Johnstown flood when they're opened and even though I kept topping it up, before I could get one of them sealed up it was too late. Didn't realize anything was FU'd until I drove another one and noticed a much firmer pedal.
    Per the JK FSM official factory bleed procedure for the service brakes is via pressure, not vacuum, but the latter would probably work ok. That has no effect on the ABS section, which unfortunately it appears has to be manually cycled by the scan tool to burp the solenoids and pump unit. I pressure bled about a gallon of fluid through the bloody thing and it had no effect on the mushy pedal. Crap...back to the dreaded dealer flat rate moneys.
    Quote Originally Posted by tantonio View Post
    Oh, wise guy, eh? Watch it or I'll pour more oil in your intake!
    Again, there is no need to pay the dealer to bleed the ABS. It's difficult at best to get air in the ABS, and it's not going to cause a soft pedal.
    If you ran the reservoir low, bleed the master. You can bleed all day at the wheels and still have air trapped at the master.
    Also, good independent repair shops have a bi-directional scanner than will run the bleed function of the ABS unit too. It's not all smoke and mirrors
    Good tip on the master cyl Diger. We'll try bleeding at the lines & see what happens.
    Re: bleeding the ABS and bleeding in general, here's the official procedure straight from the JK FSM:
    ANTILOCK BRAKE SYSTEM BLEEDING
    The base brake's hydraulic system must be bled anytime air enters the hydraulic system. The ABS must always be bled anytime it is suspected that the HCU has ingested air.
    Brake systems with ABS must be bled as two independent braking systems. The non-ABS portion of the brake system with ABS is to be bled the same as any non-ABS system.
    The ABS portion of the brake system must be bled separately. Use the following procedure to properly bleed the brake hydraulic system including the ABS.
    NOTE: During the brake bleeding procedure, be sure the brake fluid level remains close to the FULL level in the master cylinder fluid reservoir. Check the fluid level periodically during the bleeding procedure and add MoparŪ DOT 3 brake fluid as required.
    BLEEDING
    When bleeding the ABS system, the following bleeding sequence must be followed to insure complete and adequate bleeding.
    1. Make sure all hydraulic fluid lines are installed and properly torqued.
    2. Connect the scan tool to the diagnostics connector. The diagnostic connector is located under the lower steering column cover to the left of the steering column.
    3. Using the scan tool, check to make sure the ABM does not have any fault codes stored. If it does, clear them.
    WARNING: When bleeding the brake system wear safety glasses. A clear bleed tube (1) must be attached to the bleeder screws and submerged in a clear container filled part way with clean brake fluid (2). Direct the flow of brake fluid away from yourself and the painted surfaces of the vehicle. Brake fluid at high pressure may come out of the bleeder screws when opened.
    NOTE: Pressure bleeding is recommended to bleed the base brake system to ensure all air is removed from system. Manual bleeding may also be used, but additional time is needed to remove all air from system.
    4. Bleed the base brake system. (Refer to 05 - Brakes - Standard Procedure)
    5. Using the scan tool, select ECU VIEW, followed by ABS MISCELLANEOUS FUNCTIONS to access bleeding. Follow the instructions displayed. When finished, disconnect the scan tool and proceed.
    6. Bleed the base brake system a second time. Check brake fluid level in the reservoir periodically to prevent emptying, causing air to enter the hydraulic system.
    7. Fill the master cylinder fluid reservoir to the FULL level.
    8. Test drive the vehicle to be sure the brakes are operating correctly and that the brake pedal does not feel spongy.
    The bleed function of the HCU simply consists of it cycling its pistons to purge air from itself. It does this while the hydraulic system is closed so, any air that is in the HCU enters the base system. That's what requires the second bleeding of the base system.
    The only way air is able to get into the HCU is by being new/rebuilt, or, activation of the ABS with a lot of air in the base system. This is hard to do in itself as you would not have enough pedal pressure to be able to activate the ABS in the first place.
    Thanks, Digger, great explanation. After I put the lines on last year the ABS light came on momentarily, then went out and has never come back on. ABS seems to work fine, so I think your idea about the MC is the best place to look at this point.
    YJgirl's Avatar
    Aug 2003
    Your guess is as good as mine
    Quote Originally Posted by 1BADKJ View Post
    This is partially wrong. You can use a DBRIII if it has the latest and greatest updates on it, and it does not have to be a Starscan. Older DBRIII's cannot perform the brake bleed via ABS. Take it to a reputable shop that has a newer DBRIII with the latest and greatest software on it and they can do the brake bleed for you via the ABS. And by newer I mean purchased in the last year and has software from within the last 6 months.
    TRAIL HUGGER - Enuf said.
    1BADKJ's Avatar
    Feb 2007
    Colorado Springs CO
    Quote Originally Posted by YJgirl View Post
    http://www.oemtools.com/images/Vehic...olRefChart.pdf
    Ok, well that didn't work. I pressurized the system then bled right at the master cylinder hard lines. No improvement noted. Since we had it set up with the pressure bleeder we then pressure bled the system thoroughly. Ran nearly a gallon of fluid through it but no improvement. So, we'll just have to let the dealer try the Starscan routine and see what happens. Wacky.
    emm... yeah not so much. The DRBIII does not have CAN bus capability. A StarScan or aftermarket scanner with CAN has to be used.
    Jerry, something to look into, does the ABS on the JK have a relay? If your taking it to Lance, maybe he could take the relay out and jump the terminals to activate and cycle the pump. Or if it is just a 12V motor on the pump, disconnect it and cycle it. I have been able to do this on my '05 Dodge before to check the fuel pump. Maybe also if you burn that thing to the ground you could start over AGAIN
    Also, since you changed out the brakelines when this started, maybe there is one that is not sealing right and sucking tiny amounts of air in. I had a fuel injection system kick my butt one time because of this scenario. The stupid filter would not leak fuel, but it would suck massive amounts of air causing me a bunch of problems. Remember that Scout Buggy I had? I sold that sucker on the spot to a guy because the POS would not run. He took out the filter and bingo! It ran fine for him.
    My name is Daniel. I pretty much do what I want.
    YJgirl's Avatar
    Aug 2003
    Quote Originally Posted by Digger View Post
    You are right Digger. I didn't look at what model I have and its not DRBIII. Its an aftermarket one with CAN.
    My bad for not actually looking at it.
    Quote Originally Posted by AMXROCKRIG View Post
    The old (and I do mean old) ABS systems would let you trigger the pump the way you describe. Not sure this thing will let you touch anything electrical without running home to its mommy over at the dealership. What's better is Jeeps field service manual. WORST FSM/technical support doc I've ever seen (and I worked for a Brit car company). There's more useful tech info in a Wheaties box..no wonder these clowns went bankrupt.
    Short of torching this SOB I'm just going to bite the proverbial bullet and let the dealer run the Starscan ABS routine on it. We'll see what happens. Other than when I changed the lines out it has never had any air come out when I've bled them and there's no sign of seepage anywhere. I was going to try pressurizing the system with the pressure bleeder and then cracking open the lines on the ABS unit but decided the thing would probably go into some kind of electro-seizure and need a tow truck.
    Had the local dealer run the Starscan ABS bleed routine on Wednesday. (The same one who always overfilled the oil on my Grand Cherokee, and left the filter loose on the JK last time I had them service it. I do it myself now.) I got it back and NO CHANGE. Yesterday I put the pressure bleeder back on for one more burp before I throw up my hands and shoot this SOB. Hmmmm...bubbles came out of the left rear...hmmm, bubbles came out of the right front...hmmm, pedal now seems fine.
    D'ya suppose after the tech ran the Starscan ABS bleed routine he then bled the main system again like the book says to do, huh, like the procedure in the book THAT I PRINTED OUT FOR HIM SAYS TO DO?????!!!!! SHIT, NO!!!!!
    Oh, well, I did what I could. At least I now have some brakes.
