Thread: CJ5 Comp Cut Corners
September 10th, 2010, 01:36 PM #1
I am looking for a set for my 5 and after talking to poison spyder, it turns out they no longer make them.
Anyone know if I can get a set of ones for a 7 and just cut them down to fit? Or of another company who can make them or maybe someone can make a set for me?
September 10th, 2010, 01:52 PM #2
Check with T&T Customs, they might be able to make a corner blank for you that you can trim to fit.
2006 WK 5.7 Hemi
September 10th, 2010, 05:13 PM #3
there not hard to make I made some for the flatie Ill try to get some pictures just hard in a tight garage to get a good pict
>>>>>>YOU TALKIN TO ME <<<<<<[CENTER][SIGPIC][/SIGPIC][/CENTER]
September 10th, 2010, 05:49 PM #4
go to Blue Torch Fab!!!! had them on my cj7
http://www.bluetorchfab.com/Modified Cummins Turbo Diesel Tow Rig
71 FJ40- 383stroker/ 700R4 /Detroits
September 10th, 2010, 05:53 PM #5
I will send both treks and blue torch emails to see what they can do. Thank you.
4.0Cherokee - How did you do the bend? I was think I could bend 1/8 around the corner maybe on my own but not sure. Also, don't know if that would be thick enough to really protect but possibly.
September 10th, 2010, 07:53 PM #6
first off I have 1/4 inch wasn't easy I cut relief cuts on backside 1/16th deep
Before I bent it I mounted so it could be marked for bending
Also did full body armor
September 11th, 2010, 08:30 AM #7
I wouldn't consider diamond plate aluminum as "armor".
September 11th, 2010, 09:18 AM #8
It takes alot to dent it Ill tell you that and it sure aint light
September 12th, 2010, 10:23 PM #9
heres a better veiw
Comp Cut Corners?
By cajun tj in forum General 4x4 DiscussionReplies: 6Last Post: April 19th, 2007, 06:54 AM -
never cut corners
By g_dub in forum General 4x4 DiscussionReplies: 49Last Post: April 11th, 2007, 05:01 PM -
PSC Comp. Cut Crusher Corners - TJ Install?
By RockcrawlingTJ a.k.a. Justin in forum General 4x4 DiscussionReplies: 14Last Post: March 3rd, 2004, 02:29 AM -
Do you have to run comp lifters wiht comp cams>
By ColoradoToy in forum General 4x4 DiscussionReplies: 7Last Post: January 4th, 2004, 07:01 PM
Buena Vista memorial...
Today, 06:13 PM in Trail Talk
