Results 1 to 28 of 28
    Lilly Bear ColoradoXJ's Avatar
    Sep 2006
    Who knows... Orientation: Snow Lover
    XJ Long Arm build... Took awhile, but its done!
    Here we go... So for the last 4 years, i've been bouncing the XJ along on 5.5" of short-armed suspension HELL. Was talking about doing this forever, and finally just pulled the trigger and made it happen...
    First, a few thanks...
    ClemsonKrawler
    BigDave (and Pam)
    Bauer
    and anyone else who helped with this... I know, i'm a PITA
    Here we go. A couple before pics...
    The brackets I used are from PolyPerformance. Pretty sweet, if you ask me. They envelope the unibody rail, and can be bolted in as well as welded. Keeps the 4-link, plus trackbar.
    After bolting them in, I went back and cleaned up the area to be welded (and yes, I did clean up ALL the places to be welded, not just those shown )
    A few welds, and...
    Didn't fully weld everything at once. We went through and stitched, so as to minimize excess heat in any one place on the unibody rail for long.
    Trying the lowers on for size... Since I figured that I wanted to go (severely) overkill, I ordered 2" solid aluminum links, drilled for 1.25" shank Currie Johnny Joints. For all 4 links. Pretty sure the XJ will fall apart around the suspension.
    The links were machined by Performance Cryogenics... a referral from ClemsonKrawler. They're sweet
    Clemson getting to work cutting parts of MY jeep... suppose that's okay since I flopped his last year
    The other side, pre-cutting
    Old bracket off... and arm bolted up
    To be continued...
    Please consider contributing towards my Summit for Someone effort, benefiting at-risk urban youth.
    http://www.summitforsomeone.org/donate?page=4&climber=8574
    AND... don't forget to Stay The Trail.
    looks good
    87yj No drivetrain 235's 2" BL HP D60
    99 Dodge 2500 CTD with a lot of go fast goodies
    69 Camaro, 03 Kaw. Ninja ZX-6R
    Sep 2006
    Here's the first peek of the lowers bolted up:
    And "flexing" out a little on the trailer... Mind you, I only had front-wheel drive for this, since it was on the way back from Moab and my "lets blow up the spider gears on Poison Spider Mesa" debacle.
    A couple quick shots of the old axle-side upper mounts... just for comparison
    Thank God for that TnT truss... or I probably would be on my 4th D30 by now
    Axle... Out... Approaching the point of no return
    Oh man... let the cutting commence!
    Figured since it was all out, that I would get rid of the useless steering-stabilizer mount and clean up the axle as well (haven't run one in a couple years anyway... )
    All cleaned up
    And again, while it was out, and while I had extra 1/4" plate... might as well box in the stock lower control arm mounts on the D30 (As Wally would put it... "Polishing a turd" )
    Dave trying to get this done so I could get out of his garage
    We used 1/4" plate for the new brackets
    To be continued... again.
    Sep 2006
    Quote Originally Posted by hightimes2 View Post
    looks good
    Thanks. This was definitely an adventure... and its not over. I think having the heavy-duty suspension is leading to some other things that need addressed...
    long arms was the best thing I did to my xj when I had it. 6.5" coils and short arms sucked lol
    Sep 2006
    I was actively trying to get finished, so there are not many pics, but here's a few of things bolted up and in place.
    Ooohhh... shiny
    Yay! I was a little concerned about clearance, but hasn't been an issue yet.
    Passenger side, all bolted up. Damn links are beefy...
    A view from the back. A new crossmember/skid is on the "to-do" list
    So after everything was bolted up, checked, etc... It was time to hit the trails. Why not start on Black Bear?
    Much, much, much nicer ride... Smoother over the rough sections... Better handling on the road too (at least in my opinion).
    A quick shot back on the drivers side
    And then for the final inspection... its very important to get a clear view of the suspension components
    Nothing seemed out of place from that angle, so I moved it a little...
    Pam gives it a as well
    liamxj's Avatar
    Sep 2003
    Wheat Ridge
    Turned out nice. i love those brackets and want to use them on mine now that i see how nice they turned out on yours. and welcome to the wonder full world of long arms!
    Will
    PS do you have a picture on the driver side of how they go by the fuel lines and that dumb fin that hangs off the unibody in that area?
    05 Ram CTD
    50 CJ-3A
    93 Yota
    Good choice of brackets, link material, bushingless joints, and set up. Great write up on how to do it right. Nice work.
    MN-XJ's Avatar
    Denver Highlands
    Well done sir!
    P.S. Get a new tie rod! You've pushed your luck with that dinky thing long enough
    '98 XJ/5.5 TNT Y-link
    -Weekends are for catching up with the life you miss during the week-
    Looks good Justin. I love my long arms! Why do you still have the d30?
    92XJ, with a 98zj 4.0,internal cage, 37's, R.E. 7.5" coils, alcan 8"leafs, arb's, HDd60r, d44 front w/alloy shafts & ctm ujoints. Corbeau seats w/4pt harness, etc, etc.
    Nice job.Never got to experiance stock suspension in my TJ.Don't even think I've lifted a tire on Spring Creek,Wheeler and Twin Cone.Was told on Wheeler(V notch)that the long arms probably saved me at least a flop.
    97 TJ,Locked,Longarms,37"x17"s,HP D-60 Front,14 Blt Rear,4.56 Both.Patrick.
    YJgirl's Avatar
    Aug 2003
    Your guess is as good as mine
    I'm so proud of you Justin!!! XJ is all grown up and you're already putting it on its side.
    Now you need a sticker across the back that says:
    I'M MORE FUN THAN YOUR BOYFRIEND.
    TRAIL HUGGER - Enuf said.
    Sep 2006
    Quote Originally Posted by liamxj View Post
    I don't think i have a pic of it, but the "fin" stays in place on both sides, creating a channel. The upper CA actually bolts through into a little plate/nut that slides back there. I can try and grab pics early next week. Fuel lines just stay in that channel.
    Quote Originally Posted by MN-XJ View Post
    Well done sir!
    Hey now... that's at least a ZJ tie rod
    Quote Originally Posted by strom911 View Post
    Cause I got that one for a steal... and the biggest this rig goes is 35's, so properly built, a 44/30 combo should be okay. (I say this now... )
    Quote Originally Posted by YJgirl View Post
    I don't know what to say to you right now...
    Sep 2006
    Disclaimer... I don't know if its just my computer, but TinyPic is hosting a bunch of other pics apparently with the same code...
    If it ain't jeep, I didn't post it...
    Sep 2006
    Quote Originally Posted by Impaired View Post
    Thanks man
    All I see is stationwagon pics
    Sep 2006
    Quote Originally Posted by Oscar View Post
    funny...
    Nice Job! Those Poly pro backets look tha bomb yo!
    1993 YJ, 4.0, 103' WB, D44s, ARBs, SOA, SR, 37" Pitbulls, rear disk brakes, Hi-Steer and hydro-assist, sanden OBA, custom cage, tube fenders, boatside rockers, PS comp cuts.
    www.rockfrogs.org
    clemsonkrawler's Avatar
    lost at sea... Orientation: SNOW LOVER!
    turned out good.
    Pimpin aint easy.
    al24's Avatar
    Apr 2002
    Coors Town
    X2. I didn't even know those Taurus wagons had a solid front axle.
    Any fool can criticize, condemn and complain and most fools do. Benjamin Franklin
    Sep 2006
    Quote Originally Posted by clemsonkrawler View Post
    turned out good.
    Thanks dude. Appreciate your help and to get this thing done...
    no problem. I have a feeling Im going to need the provocation returned this winter. The YJ is no more. Gonna have to build something new.
    BradC's Avatar
    Apr 2002
    SE Denver
    Looks great Justin, now go break it!!!
    www.staythetrail.org <--KEEP THE TRAILS OPEN!!!--> www.treadlightly.org
    98 TJ with stuff
    Sep 2006
    What do you want from me? I was trying...
    I think Billings sounds like fun
    Not lost CannonBall's Avatar
    Denver
    What front bumper is that? Home made?
    -Nate
    2k XJ
    al24's Avatar
    Apr 2002
    Coors Town
    Iron Scorpion
    Can't get one anymore.
    BeastXJ's Avatar
    Apr 2003
    Looks good Justin! Welcome to the world of long arms, have been pretty happy with my setup. Way to test it out on Black Bear
    99 XJ 5.5" RE LA, 4.11's, 33" TRX's, Ohana Fab sliders and some other stuff.
    92 XJ 6" Rusty's lift, 4.56's, 35" MT's, locked, sliders, Flatiron Fab tube doors and rear bumper, Iron Scorpion front winch bumper etc.
    Sep 2006
    Quote Originally Posted by BeastXJ View Post
    Go big, or go home... right? Its not like there is a penalty for suspension failure up there
  1. Toy IFS build thoughts (little long sorry)
    By 64IH80 in forum General 4x4 Discussion
    Last Post: January 13th, 2012, 07:11 AM
  2. That's It. I Quit! No jotd for awhile.
    By DaJudge in forum General Chit Chat
    Last Post: September 21st, 2008, 09:42 PM
  3. Been awhile..
    By Glock36 in forum General Chit Chat
    Last Post: August 1st, 2008, 12:15 AM
  4. Another TJ Long Arm Build
    By GPP33 in forum General 4x4 Discussion
    Last Post: June 5th, 2007, 12:20 PM
  5. The best $100 I've spent in awhile*NOW WITH PICS*
    By Jocko in forum General 4x4 Discussion
    Last Post: January 16th, 2007, 08:17 AM
