Results 1 to 7 of 7
Thread: Lightroom 3 on its way!
    Did it for the LULz Jeffro600's Avatar
    TOGTFO
    Anyone else tried it yet?? I absolutely HATE Betas but this one is fantastic! They finally addressed mine and several others complaints about noise reduction and sharpening being available at all zoom levels instead of just 100%. Cant say im thrilled with their new import dialog box but it does seem functional...just a different layout from what im used to. The new vignette and grain adjusters seem pretty slick and the noise reduction options look awesome! The entire package runs MUCH faster...importing, exporting, previews...everything generates and works much smoother and quicker. If you havent yet, i suggest highly that you try it!
    Snagged this off another forum....
    Image Quality
    One of the primary improvements in 3.0 beta is image quality. Lightroom's been taken back to its bare bones and the raw processing engine has been given a complete overhaul. Even the demosaic algorithms have been substantially improved to give a cleaner file which will respond better to subsequent noise reduction and sharpening.
    Performance
    While Lightroom was back on the drawing board, the underlying architecture has been completely reworked to improve the performance, particularly with large catalogs. It's still in early stages at the moment, but the basis is there for a great final release.
    The preview system has also been redeveloped, so the thumbnail grid won't keep going fuzzy as you scroll!
    Import
    • Entirely new Import dialog, with compact and expanded views, depending on the level of control you need.
    • It has panels like the main modules, including Source and Destination.
    • Destination folders that will be created by the import as shown in italics so you can see exactly what will happen.
    • Import presets can now be saved and reused in both compact and expanded views.
    • There's a new Loupe view within the Import dialog for viewing embedded previews.
    • The import backup now backs up with the new filenames if you're renaming while importing.
    • CMYK files can now be imported, although all editing and output will still be RGB.
    • If you right-click on a folder in Library module, there's an 'Import into this Folder' option which opens the Import dialog and automatically sets the Destination folder.
    Library Module
    Publish Services
    • Publish Services provides integration with photo sharing websites, keeping them up to date with the changes you make in your Lightroom catalog.
    • Sync runs 2-way, so comments made on your Flickr account appear back in Lightroom.
    • Flickr is the first to be available and more are sure to follow.
    • Sync to hard drive is also available, and useful for syncing photos to your iPhone, screensaver, other networked computers, etc.
    • Filters are no longer sticky - they reset as you switch folders unless you click the padlock icon on the Filter bar.
    • There's a new badge on the thumbnails showing photos that are in a standard or Publish collection
    Develop Module
    Process Version
    • Because so much work has been done on the base ACR engine, a 'process version' has been introduced to differentiate between the old process and new processes.
    • Any images with existing settings will be set to the old process version to get an almost identical rendering as previous versions. Any new images imported into 3.0 beta will be assigned the new process version.
    • There's a warning triangle in the histogram if an image is on the old process version - click it if you want to update (also found under Tools menu).
    • Need to update to the new process version in order to use the new noise reduction, grain and vignette tools.
    • 3.0 beta will not be fully compatible with any ACR version at this point in time. Rendering may vary depending on the settings used - vignette and noise reduction would render very differently using ACR 5.5 and LR 3.0 beta.
    Noise Reduction & Sharpening
    • Lots of work has been done on improving the noise reduction without losing fine detail.
    • Color noise reduction is already vastly improved.
    • Luminance noise reduction (new process) is disabled for the beta but will be back in the final release.
    • There's a new Edge Detail slider which refines the edges on extremely noisy images at very high ISO.
    • Any old settings updated to the new process version will probably be too strong.
    • There have also been subtle changes to the capture sharpening.
    • The preview now shows sharpening & noise reduction at less than 1:1 view when using the new process version, although it still needs a little work.
    Grain
    • Film-style grain sliders added give a very natural looking grain.
    • It shares a new Effects panel with Post-Crop Vignette.
    Post-Crop Vignette
    • New more natural vignette instead of just painting white or black on the edges.
    • Color Priority mode retains more natural colours under the vignette with softer shadow transitions.
    • Highlight Priority remains heavily saturated under the vignette.
    • Contrast slider brightens the highlights under a dark vignette.
    Adjustment Brush
    • The buttons are gone, so it's now either a single drop-down and amount slider, or the range of sliders.
    • New icon shows when no color tint is being applied.
    • Show/hide pins and overlays are now in the toolbar when the Brush/Gradient are active, so no more having to remember the shortcuts.
    • Crop - the list of crop ratios has been tidied up to combine identical ratios like 2x3 and 4x6.
    • Greyscale has been changed to Black & White throughout.
    • AutoTone now includes Fill Light.
    • Sync/AutoSync now has a switch next to it to easily switch between the two.
    Slideshow
    • Slideshows can now be exported to MP4 video format for uploading to video sharing websites, including your music track.
    • Mac version is no longer tied to iTunes, matching the Windows behaviour.
    • You can now sync the length of the slides to the music track length.
    Print
    • Custom Print Package
    • New custom layout option for different images in different sizes (without resorting to hacks!)
    • Drag and drop to create a flexible layout.
    • Page background color can now be changed.
    Watermarking
    • New watermarking allows a simple text or graphic watermark to be applied in Export, Publish, Print and Web.
    Backup
    • Backup has moved to quit rather than startup, by popular demand!
    • There's a new checkbox in the backup dialog to run optimize catalog after the backup.
    • Time Machine will now exclude Lightroom catalogs while they're open so that they're not backed up in an incomplete state.
    Other bits and pieces
    • The breadcrumbs bar on the filmstrip now has a Favorite Sources option.
    • The Select Catalog dialog has had a facelift.
    • Library menu > Show Missing Photos creates a temporary collection of all missing photos instead of having to go through Synchronize Folder.
    System Spec Changes
    • System specs have increased to a minimum of 2gb of RAM on Windows
    • No more PPC for Mac, Intel processors only.
    • No more Tiger - Leopard or Snow Leopard only.
    Upgrading
    This is still in early stages - even earlier stages than the 2.0 beta - so there are plenty of bugs. It's not likely to blow up your computer, but you are strongly recommended not to switch your entire workflow over to the beta at this stage. It's been released for testing and feedback on the new features, and the beta period is likely to be longer than that of 2.0 beta. It won't allow you to upgrade 2.x catalogs to the beta, but the final release will.
    Lightroom 3 Beta is not feature-complete - there's more yet to come in the final release.
    [B][FONT="Comic Sans MS"][COLOR="Red"]Somewhere in Kenya, a village is missing their idiot [/COLOR][/B][/FONT]
    [URL="http://www.facebook.com/home.php?ref=home#!/pages/Hesperia-CA/Caught-My-Eye-Photography/366899572049?ref=ts"][FONT="Comic Sans MS"][COLOR="Blue"][B]Caught My Eye Photography[/B][/COLOR][/FONT][/URL]
    [QUOTE=Steve]I was WRONG![/QUOTE]
    Getting deep in here Hardcor4x4's Avatar
    Jun 2003
    Northglenn, Co
    I just upgraded my version to 2.6 a week ago. Its about the only photo editor i use for my RAW files. Wonder if i'll be able to get the the free downloadable version upgrade to 3.0 when it comes out or if i'll have to buy a new version just to get 3.0
    TOGTFO
    Youll have to buy it
    ColoradoSkier's Avatar
    St Augustine, FL/ Lakewood, CO
    We know there are ways around that...
    Chester Bullock
    Instagram - http://instagram.com/coskier
    My drone photography - http://instagram.com/gypsy_drone
    TOGTFO
    Of course...
    Mr. Mojo's Avatar
    Jul 2005
    Monument
    So far I am liking LR3 beta except for importing images from memory cards. Always hangs during upload on my Mac. I haven't loaded it on my PC yet.
    Seems faster in 64 bit mode over 2.6 in 64 bit mode and has built in blog uploader plugins.
    "Courage is something you can't be afraid to have." - Frank Burns
    TOGTFO
    Quote Originally Posted by Mr. Mojo View Post
    Its crazy fast compared to LR2 on my Mac...like at least 50% faster across the board with literally every action...sometimes, even faster! I cant wait for the final version!
