First Ill bring you up to current!
When i bought it looked like this, Engine had at least 200k, Smoked alot, had the original 20r,L43, 4.37 third's. rolling 33's (Fit with no lift or body lift)
I purchased a All pro lift and installed it thinking I was going to purchase bigger tires soon. took me almost a year to add big meats
With the lift I needed to Upgrade my Shocks,Steering. Its very uncomfortable driving around with the stock toothpick steering setup. Also installed a Fresh 22R w/ Carb. Few Pictures of me wiring the beast, only needed 8 wires to run the carb 22r. 4 being Alternator wires and 2 for the Distributer and 2 for Fuel cutoff, and misc wires for gauges. I Used the 20R Distributer and Coil mainly because I didn't have to modify my original coil, and ignitor. Easy swap I had to modify the exhaust and Change the motor mounts to 20r mounts, it bolted right up, I also decided to Install a L52 Transmission they are stouter then the L43 and it gave me another gear. Look at those amazing welds
As its Sits Today
Only added 38.5x15x15 Ground hawgs used for $200. Needed some rubber for winter my Hankook 33's were bald. siping is in order, and i know these tires are going to suck in the snow.
Things I have planned:
Calling Gotpropane and Getting a Propane/Turbo kit from Cary by the end of the month.
Install Square driveshaft up front, Weld up the new Spring hanger up front to give me a better front pinion angle (Not using front driveshaft right now)
Order a Dual case adapter.
Repair Any rust on the body, purchasing new Fenders, Extend my toyota Cab Picture below.
Finding a W56 Transmission or a R151 Turbo tranny (yeah right)
Purchase Lockers (ARB Hopefully), Get Longs (May have a good deal on an complete axle from AJRight?)
Regear to 5.29's.
Install Turbo flywheel, clutch The flywheel is heavier and hopefully will help with stall.
Looking at doing something like this but use an ext cab window in that Area. I have all the metal to do it Just haven't sat my ass down and done it. Tell me what ya think.
I will update as soon as Updates are done.
