Results 1 to 27 of 27
    Nov 2008
    Jeep 4.0l stuck lifter help
    I have an 02 wrangler with the 4.0L motor. It has a little less than 90,000 miles and what I believe to be a stuck lifter. There is a loud tick in the morning that lasts till the motor is warmed up 5 mintues, sometimes more or less or sometimes it wont even do it. After it is warmed up it pretty much goes away. I can brely here it atleast if any. Does anone have any idea how much it costs to fix or if there are any other solutions. To the problem. Thanks
    Dec 2001
    Are you sure it's not an exhaust leak? That sounds more like your problem. The manifolds crack and leak badly when cold, then seal up after a few minutes.
    Nov 2008
    Im not positive. What is the easiest way to fix it if its the manifold?
    Replace it.
    MIKE n IKE's Avatar
    C Springs
    Mine does that too, I shut it off immediately and re-start..........noise gone! I think the top-end is starved for oil when started cold like that. It is a common problem with the 4.0 liter. You get used to it. What type of oil are you using? Mine started after switching to a synthetic blend.
    '04 TJ Sport, 3.5 TeraFlex, SYE, LSD, 32's
    Beer, Beer, Beer said the Private.......
    MIKE n IKE's Avatar
    C Springs
    Quick way to check ......If its the exhaust, the noise won't go away after a quick re-start, rather it will keep clicking until the engine gets warmed up a bit.
    Banned Leon Phelps's Avatar
    Riding Out Into The Sunset.......
    Lifter noise is fairly common on a 4.0. Try some Marvel Mystery Oil.
    Nov 2008
    I have tried everything from a bg quick clean before the oil change to an engine flush. Right now I am running mobile quick clean 5000 10w30 with a lucas additive. I have tried the bg additive too but I thought it didnt work as well so I stuck with lucas. I have never tried the restart thing. I wil try it omorrow morning and let you know. I work at a shop too by the way and everyone seems to have a different opinion. one person has heared it only for a few seconds and htought it was the lifter. One mechanic said to try synthetic oil but I do not want to start and oil leak.
    Nov 2008
    Also with the marvel mystery oil do you put it in before you change the oil? I have never used the stuff. I have heared of people driving with it for a few hundred miles before an oil change. Is that okay to do?
    Bring it here Evergreen lets take a look possably just needs an ajustment
    >>>>>>YOU TALKIN TO ME <<<<<<[CENTER][SIGPIC][/SIGPIC][/CENTER]
    I've always put a pint in with oil change helps save the valves on older motors also helps if you burn alot of oil ,granddad tought me that trick
    Dec 2001
    What are you going to adjust on a 4.0's non-adjustable valvetrain?
    Quote Originally Posted by 4.0Cherokee View Post
    umm...
    Quote Originally Posted by Norco View Post
    yeah... what Norco said...
    Nov 2008
    I tried that this morning and it worked. it cam back after about a minute though but wasnt very loud.
    typed that to fast with out thinking about what engine it was my bust
    Quote Originally Posted by ENHRider14 View Post
    time for a set of lifters.
    Have you tried a thinner oil (like 5W-30)? Does it make the noise in warm weather or only when it's cold?
    I'd try a different oil. I used to have an old Montero and when I used some cheap-ass oil it started to tick badly. Switched to a better oil and the problem went away. (It's the only time I've ever noticed any difference in switching from one oil to another).
    Quote Originally Posted by Digger View Post
    He'd probably have to replace the cam along with the lifters, correct?
    Dec 2001
    Only if the lobes are flattened. Old cams can use new lifters but it's considered extreme duty break in all over again. New cam old lifters, old cam old lifters on different lobes = carnage
    clemsonkrawler's Avatar
    In the Freezer... Orientation: SNOW LOVER!
    Saul?!?! That you?
    Pimpin aint easy.
    Quote Originally Posted by clemsonkrawler View Post
    Saul?!?! That you?
    NO! I read FrankZ's story of cam/lifter issues
    "When Murphy wrote his law he was thinking of YOU" - JRVYota
    '91 XJ, 6", Long Arms, Locked, Plated and Stiffened, 33"s
    '04 Impala 9C1, L67, 14Psi, 3.29's.
    '76 Camaro 358, 112 octane, 5.79's, Welded.
    MIKE n IKE's Avatar
    C Springs
    Same thing here, I don't think its a problem though, still runs like a champ. I put some serious miles on mine and it hasn't gotten worse. If it wasn't making some crazy noise it wouldn't be a jeep!
    Nov 2008
    Right now I am running 10w30 oild with lucas oil stabalizer. I am doing an oil change this week and am going to try 5w30 and see if it helps. Its does it more when cold.
    MIKE n IKE's Avatar
    C Springs
    Yeah, in the summer its almost non-existent unless I'm in the mountains camping where its cold at night. I wonder if the oil galleys are too small or if the pump is just kinda weak in these motors?
    no... they just have occasional lifter bleed down problems.
    Nov 2008
    Once again I tried the shut if back off and restart it and it works miracles. It makes it quite enough to not be annoying when it is warming up. Thanks
    Dec 2006
    Fort Collins, CO
    Could be piston slap but unlikely. Probably exhaust manifold (or its gasket) or lifter, potentially a broken valve spring. Try 5w30 synthetic oil with no additives. Synthetic oils have great detergent properties.
    You could also ask on bobistheoilguy.com forums if it's really bugging you. That group is full of tribologists and some dude over there sells a engine oil additive that really does clean stuff out, but slowly so you're not plugging oil galleys and such.
