Results 1 to 19 of 19
    MinesJeep's Avatar
    Nov 2006
    Live/Work Littleton/Evergreen
    Chevy S10 2WD to 4WD conversion
    Alright so the girlfriend just loves her truck and she's not in great position to trade it in for a pick up with 4wd. It's just a regular S-10, not sure what axels are underneath. Any information on getting started to converting to 4wd and what it would cost is appreciated.
    TIA
    Tony
    willys's Avatar
    South of Johnstown
    I covernted a Bronco II to a 4wd and I purchesed a wrecked 4x4 that way I had any and all parts that I needed. It was cheaper than buying the parts as I needed them. Good Luck.
    [COLOR=DarkOliveGreen]TITE-ASS ENGINEERING, BUILDING GREAT THINGS FROM ALMOST NOTHING.[/COLOR]
    Frames are completely different.
    2wd = coil sprung, 4wd = tortion bars
    you'd really be better off getting a 4wd truck
    When the ZOMBIES come, You'll find me at Walmart surounded by spent shell casings and empty bottles of burbon,
    MinesJeep's Avatar
    Nov 2006
    So if changing the suspension over was an option ( big if I know) what are we looking at in costs? I just want real numbers to tell her so I can convince her to jsut let me sell the truck and buy something with 4wd already for her.
    Costs for you to do it or to have it done?
    For a shop to do it I would guess $3000-3500 at a bare minimum.
    MinesJeep's Avatar
    Nov 2006
    Yeah, we would be doing all the work, she's actually good with cars, I'm just mechanically retarded.
    Can you both fabricate, as in cutting, measuring, and welding?
    This isn't a bolt on procedure.
    Banned Gunter's Avatar
    Oct 2003
    Quote Originally Posted by MinesJeep View Post
    the biggest deal is getting your axle.the rest for a chevy is just parts changing.
    i'd say fix the rear first,then make the front match the rear with whatever axle you choose.waggy d44 up front and maybe a 10 bolt GM or a 12 bolt rear from a blazer,both would be the same 6 lug. should be able to find both in same gear ratio.or both axles from a full size blazer.
    my choice for the ranger was for the bolt pattern for both was the same,and both had the same gear ratios too.that saved a lot of money up front.
    i'd say as for the work,coils vs leaf no big difference in amount of work. you can stop by and see what i have going over here if you want,same basic project in progress.
    MinesJeep's Avatar
    Nov 2006
    Alright, so my thoughts, why would we need to change to from a coil suspension to a torsion suspension or leaf suspension. Shouldn't we just need to change the axels and the driveline?
    The coils on the front end are between the upper and lower a-arms, not between an axle and frame.
    Go look at it first, then ask questions. It's nowhere near as simple as you think.
    Nov 2006
    Longmont, CO
    Because it's IFS.
    OR, you can do a Solid Axle Swap, which is what Gunter is talking about above. It will be stronger offroad, but in all likelihood not drive as well onroad.
    Seriously, you're looking at quite a bit of cutting, grinding, and welding to convert it. If you can do that, great. If you have even the slightest doubt, just buy a 4WD. I would recommend a Toyota LOL
    President, CO Chapter TTORA
    Check out www.ttora.com, and www.yotatech.com to 'wheel with great Toyota folks!
    1993 Toyota 4Runner with some armor, lockers, dual cases and stuff ...
    Stop with the mods and get on the trail!
    Jul 2006
    Pensacola, FL
    Tell her 5k and to go see someone at a stealership about trading it in
    Quote Originally Posted by CSP View Post
    CSP is right on this one, Tony. This is one heck of a project. You have no idea........basically, from what I know of your situation, not even one I'd recommend you consider.
    MinesJeep's Avatar
    Nov 2006
    Good, thats all I really wanted to hear from everyone. We went to the stealership yesterday and they only offered her 4k for her 10k truck
    Jul 2006
    Pensacola, FL
    throw it on craigslist you never know, someone might be looking to spend 10k on a 4k 2wd truck.
    MinesJeep's Avatar
    Nov 2006
    Yeah, I threw it on there for 11k and already got a response.
    MinesJeep's Avatar
    Nov 2006
    Thanks, everyone for the feedback. I knew it would get this kinda response, but she wouldnt relent until everyone said it just wasnt feasible.
    Fabtech makes a killer sas kit using a dana 30 out of a cherokee.
    Build a pre-runner out of it. CST and Velocity fab and Total Chaos make KILLER long travel kits for s-10's check it out. Trust me shooting walls is fun catching air at 60 is a rush.
    yeah i did it
  1. 1953 Chevy truck conversion to a 4x4 frame?
    By rescue6 in forum General 4x4 Discussion
    Last Post: March 17th, 2009, 04:02 PM
  2. Chevy Rear Disc Conversion
    By gumcrew2 in forum General 4x4 Discussion
    Last Post: November 7th, 2008, 07:16 PM
  3. Chevy D44 front disc conversion?
    By svoman2300 in forum General 4x4 Discussion
    Last Post: January 29th, 2008, 03:02 PM
  4. Chevy Auto Hub To Manual Conversion
    By TW in forum General 4x4 Discussion
    Last Post: August 25th, 2006, 08:10 PM
  5. Chevy Straight Axle Conversion
    By Trailer Rails in forum General 4x4 Discussion
    Last Post: April 28th, 2004, 04:00 AM
